Dutch sailing barge
Followers (16)
- chugalone100Silver
- zoomaBronze
- luckyduckBronze
- Mike StoneyBronze
- roycvBronze
- deeprivermanBronze
Dutch sailing barge
Several of my boats have had a dozen or more coats and this stabilises and hardens and even 10+ years later just need a wipe down. Do not forget to paint or varnish the inside to prevent wet air creeping in.
It also sometimes helps to decide what colour suits best. Keeping old brush on paints can be difficult. I have come to the conclusion that paints dry out and go hard if there is more air to paint by volume.
Bashing the lid on the paint down helps and also storing upside down which prevents air coming in assuming no paint leaks.
Any other hints and tips?
Dutch sailing barge
Dutch sailing barge
The underside of the hull needs priming and sanded smooth - think that will be the next task.
Dutch sailing barge
It would be nice to see the Lee boards radio controlled.
Dutch sailing barge
Groene Draeck Queen Beatrix's royal yacht. It googles to find it.
Dutch sailing barge
I’ll look at painting and finishing the cabin roof, then the next job will be the Lee boards.
Dutch sailing barge
Looks perfect already . . . Congratulations!
BB Michel-C.
Dutch sailing barge
Before RC was everywhere when I lived in Hampstead I saw a model Dutch barge which had working Lee boards. These were automatic and were controlled from a mercury switch, I think there were 2 of them.
As the hull tilted to one side or the other the switch would turn on, and an electric motor would drop which ever lee board it was using a chain.
Did you give a thought to just having a servo on its side directly coupled to the lee board?
Dutch sailing barge
The handrail along the edge of the roof needs to be added but I'll need some 2mm dia brass rod and will then add a further 4 supports each side.
Dutch sailing barge
Dutch sailing barge
I am always in favor of both fuses (and I think this is understood well) and capacitors.
Capacitors are not always essential but they have no contraindications so I am always in favor.
Will you choose the "top" configuration with three capacitors on the brushed electric motor or the minimalist one?
Dutch sailing barge
Made some card templates for the pieces of deck, before making and fitting the final pieces.
Dutch sailing barge
It would be better to buy a low-cost (relatively low) radio control with at least six channels.
The radio control you have can be used in the future for a boat that requires fewer channels. How many channels do you have available.
Last year I bought a fairly cheap six-channel radio control.
Dutch sailing barge
The next step is to get the rudder and sail servos in and working, along with the motor control. That will use all the controls up on the Rx/Rc. Not using the motor control would make room for a servo/winch for the Lee boards. Decisions ?
Unfortunately I don’t subscribe to Facebook etc but thanks for the suggestion
Dutch sailing barge
It seems like a great idea, but I suggest another method: Instead of using a winch (the ones used to wind the sheets) use the servomechanism normally used to control the rudder.
In this case there is no need for the lee boards to be weighted to fall back down. In fact, the complete movement in one direction (lifting the board out of the water) and in the other (lowering the board under the water) will be guaranteed entirely by the servomechanism.
The rudder servo has a small excursion (no more than 90 degrees) which is sufficient for your purpose I think.
You can decide whether to put one for both lee boards or one for each lee board.
In the first case you will have to build a system to transfer the movement to a common axis that connects the pins (fulcrums of the movement) of the lee boards.
In the second case you could attach the servos directly or with a minimum of gears.
I prefer the simplest solution, one servo for each lee board, attached directly. However, I don't know if it will be possible for you because you could have difficulty hiding them. In that case, if you have to position them lower in the hull you must perhaps use a movement transmission system (for example with gear wheels and belts or just with gear wheels).
Lifting the lee boards with a winch could instead be a problem because as far as I know they make four or six complete turns. Even just four complete turns could be too much for your purpose.
However, it is a problem that can be solved.
I hope I explained myself well.
Dutch sailing barge
It could be possible to use a sail winch mounted sides ways, so the lee boards could be raised and lifted, on a push/pull arrangement - but the boards would need to be weighted to ensure they dropped as the line from the winch was eased. The other option would just have them adjustable and made so they could be fixed in a down position.
All ideas to be considered.
Dutch sailing barge
Dutch sailing barge
The topsides are made from 1.5mm thick plywood. The line of the gunwale has been marked out and this will be glued in place, before the excess plywood is trimmed off.
Currently thinking about where/how the two sail winch arms will be fitted - the plan is to use two HiTec 765's. The roof of the cabin will be removable, as will the the cockpit - but have yet to decide how to achieve this.
Dutch sailing barge
Colour? White initially, then perhaps red oxide or black under the water line. Think the rubbing strake will black, but that’s all along way off. A few coats of white and lots of rubbing down will be needed first.
Next task, the rudder and operation via a servo.
Dutch sailing barge
The beauty of boat modelling is that if you make a mistake or want to change the boat you can. And at only a mere fraction of the cost of the real thing, and cheaper than a round of golf ! 😉
Dutch sailing barge
Dutch sailing barge
If you don't want to do the second planking, don't worry, this is already very good.
Dutch sailing barge
I use cocktail sticks for wood nails (trenails) with a bit of PVA glue on them and hammer them in. Mainly on mast repairs and they work a treat.
Also bamboo skewers are a good source and cheap as well.
Dutch sailing barge
Dutch sailing barge
Thanks for the video Ross - interesting but the challenge on a Dutch barge (or similar) is the bow, where the planks have to bend round 90 degrees, as the bow has the cross-section of a football, rather than a fine cutting edge, as found on a classic J class yacht.
Dutch sailing barge
Dutch sailing barge
Dutch sailing barge
Aren't you going to do the second planking?
In the modeling field, the second planking is a very useful custom.
All you need to do is sand the hull you have already made well and then place other strips.
The work will be much easier and can be much more precise by having a complete support and gluing surface.
The idea of brushing the inside of the hull with epoxy resin is still excellent, in my opinion.
I would have done this operation after completing the second planking.
You will get a much more resistant and waterproof shell.
For the second planking you can use very thin strips.
Dutch sailing barge
I'd be interested to see how the planking is completed on the full size version, as it seems they use fewer but wider planks.
Dutch sailing barge
Dutch sailing barge
I have a fishing boat with a rarely used prop. My thinking was that a coarse pitch propeller would be less drag.
regards
Dutch sailing barge
However, as we should always be interested in learning new things, the decision was made to add the auxiliary power source. The actual prop size is currently 40mm, which just fits. I look some advice and the motor size was recommended, as was the specification for the speed controller. The motor/prop will only need to move the boat slowly when there is no wind, but that is along way off yet and we need to remember it is a sailing boat.
You can still hire sailing cruisers on the Norfolk Broads that do not have a motor. Such joy and thus skill needed.
Dutch sailing barge
Dutch sailing barge
Am I wrong or did I get it right?
Is this an out-of-shape addition or does it replace a wooden part?
In any case, excellent choice.
I used this trick too.
In the ship I called Francesca I simply added steel bars.
I went outside the shape I had planned, but only by a cm (so it's not noticeable).
In the schooner I am finishing building I have instead refined the method.
The trick is this: When I designed the keel I created a pre-cut part.
After completing the hull planking, I removed the wooden part and replaced it with a brass bar.
Afterwards I continued the planking in mahogany strips on this part too.
This way you can't see anything and I don't go out of shape.
In any case, both methods (one faster and more hasty, one more accurate) allow me to have excellent lateral stability without resorting to the bulbous fins that protrude under the keel.
Personally, I don't like those fins under the hull and they don't allow me to navigate in shallow water.
Dutch sailing barge
Good luck with the rest of the build, and enjoy it ! 😉
Dutch sailing barge
Decided to add the flat bottom, from 1.5mm ply, an initial paper template helped get the shape close, before final fitting. Plan is to then add two lines of planks at the bottom, before completing the rest.
Dutch sailing barge
Not only will it be useful for the absence of wind but also to facilitate turns if the rudder is not large enough.
Are you sure the motor is powerful enough for the propeller you put in?
I don't want to be wrong but it seems a little small to me.
Furthermore (this is not a criticism but a suggestion) perhaps you should put a fixed joint (not cardan).
This way you can align the engine perfectly before locking it onto the supports.
Then (once you have found the perfect alignment) you can also choose to use another type of joint.
The perfect alignment will reduce vibrations, noise and consumption.
I wrote you my opinion because you still have time to decide. I hope I explained myself.
Dutch sailing barge
The plan is to have an additional/detachable keel, which will be bolted through the brass tube. Still thinking about the linkage for the rudder but will get it fitted before any planking is added. However, there is a slot in the underside of the rudder, so this can be extended while sailing, which should increase its control.
Dutch sailing barge
However, some decisions are needed about the rudder, this will need a removable piece to be used while sailing, which is quite easy to achieve but its the lower rudder bearing (pintle) that needs some thinking about. There is length of brass, 1/2 inch wide, that will form the bottom of the keel. This will add some weight low down and keep the wooden keel straight, as well as protected. It will form part of the lower rudder bearing.
Dutch sailing barge
Obtained a copy of the "Dutch Yacht" plans, having scanned these, it was possible to "double" the size, so the planned model should be 37 inches long and 12 inches beam. The article in the 1975 issue of model boat is quite short but interesting, as is a book "The Dutch Barge" - more historical but does provide some information.
Just need to start - what could go wrong ?
Dutch sailing barge
Dutch sailing barge
I’d had a look at the Thames barge kit, Veronica, by Sarik.
Have ordered the drawings MM1203, £15 with postage, so worth a look. A model of twice the suggested size, should be ok. I’ll have to learn how to scale up!
There’s even some copies of the June75 magazine on eBay !
Dutch sailing barge
Dutch sailing barge
Most model Thames barges sailing in competition are to half inch to the foot scale which gives a hull about 48 inches long. Yes you do need a sailing keel and this makes them very heavy.
The barge boards do not give enough effect to prevent leeway but can easily be made to operate.
I first saw this about 60 years ago with a Mercury switch controlling the movement. When tilted to one side allowed that Lee board to lower. As they have either one or the other down the switch decided which one. But with RC a lot easier to control now.
The leading light in AMBO some years ago was Richard Chesney, we first met when we were queuing to receve medals at the old Model Engineering exhibition about 1990. He produced a very nice booklet on everything you need to know about making model sailing barges.
I have a copy it is complete but maybe a little dated now. I am happy to pass this on to someone provided they will make the contents available to all interested.
Duplex Craft the fore runner of HFM plastic model kits, best known for the small yachts 575 and 590, produced a smaller 30 inch hull and barge boards of the barge Venta, plans for this are available from Sarik. It makes up into a nice model.
I have seen the Billing kit William Everard sail but it is a bit small. The full size Will Everard does sailing excursions in the Thames and around the East coast of England. It had to lose the Everard family name and the new owners retained the name 'Will'
I was on one such trip on the Thames a few years ago with my daughter and took the wheel for nearly half an hour coming back from the Thames Barrier. Very slow to react so need your wits about you.
There is much written about Thames barges and many were saved and there is nothing like seeing one in full sail in a good wind.
regards
Liked by
Loading…
