Question of the Day?
Followers (74)
- chugalone100Silver
- NickthesteamSilver
- cumbraeSilver
- Stour-boyBronze
- EdWBronze
- zoomaBronze
- RNinMunichBronze
- Commodore-HGold
- Mike StoneyBronze
- WolleSilver
- TonyAshSilver
- jumpuglyGold
- SimpleSailorBronze
Showing the most recent 50 of 74 followers.
Meanwhile thinking again what can be done to improve the daily questions…
Scrap sailing questions, more historical nautical questions (these seem to be popular), I did consider the option of a free text ‘none of the above’ option, but realistically we want these questions to be factually correct in the first place… I think well referenced evidence of the correct answer and reason for it should be added too.
Once I’ve time to work on this, I will do. The last thing I want is everyone to be annoyed at the inaccuracies of it all the time.
Stephen
It has 2 ropes (sheets), one each side of the yacht, and when tacking the taut rope is released and the other sheet hauled in and the sail goes across the bow area.
When furling the sail up there is a sort of winding device on the forestay that winds the sail back around the forestay.
There is often a dark stripe of material on the sail, this is not decoration. It is a strip of material that resists UV light and helps preserve the sail, sometimes known as a sacrificial strip.
It can also be easily replaced if necessary. When the sail is fully furled the dark strip completely covers the sail.
Hope this helps.
See piccy.
trev
I was just about to suggest to Stephen (Fireboat) that he cap/delete the 'Quiz' thread where I responded to MikeC2. But when I tried to go back to it to do that I found it gone: 'Invalid Forum Thread'. He'd beaten me to it👍👍
BUT! Unfortunately there are still 7 other threads re the Daily Quiz with the same problem; they bypass the anti-spoiler Stephen built into the QotD thread🤔
See attached Screen Shot.
Doug😎
PS: I notice also that Mike's post has been transferred to this thread👍
God, and our First Lord of the Model Boats Admiralty, move in mysterious ways😮😉
Ref your post on the Quiz thread.
I'm posting this here coz Quiz is an open thread and would betray the answer to anyone who reads it! Not sure quite what you meant by your cryptic but I don't think The Inner Farne Lighthouse is famous for anything particular.
From Unca Wiki about the Farne Islands.
"Lighthouses
The lighthouse's curved brick foundation supports the stout conical red-and-white-striped tower and adjacent building.
Longstone lighthouse in the Farnes from where Grace Darling and her father launched their rescue.
Currently, two lighthouses are operated by Trinity House on the Farne Islands:
Farne Lighthouse was built in 1811 and originally named Inner Farne Lighthouse.
Longstone Lighthouse was built in 1826 and originally named Outer Farne Lighthouse."
There are several entries about the Farnes, many with a colourful mix up of the names and former names of the lighthouses.🤔
But ONLY ONE with a connection to Grace Darling.
No wonder the AI algorithm got it's digital knickers in a twist 😮
https://en.wikipedia.org/wiki/Farne_Islands#Lighthouses
Another wrong guess and learned something in the process
Riddle greetings
Michel-Cl.
"It is an Offence the throw stones at this notice".
I guess a lot of Australians have a sense of humour too!
I have sailed along the UK south coast and all was sweetness and light.
On the canals around Birmingham and before the whole lot was cleaned up, going under a bridge could be a problem.
After experiencing small boys dropping stones on the boat. My brother and I decided to go ahead and see what was waiting for us and we sometimes had to chase the little s**s off.
But since those days the very large canal basin, I think more canals than Venice, has been made a feature of Birmingham and probably it does not happen now.
Neglected areas enable more trouble to appear. Some years ago councils made sure any damaged notices would be repaired straight away. Which apparently has the desired effect. An area allowed to run down costs more in the end than one that is maintained.
However there is rage when some people just loose their temper for whatever reason. Also bad behavour.
In Sydney Harbour, probably 10 years ago, we were anchored up (yacht). We were there to see some event and a 30 odd foot motor boat found a not very large space to anchor in.
The boat stopped and then was slowly drifting down on us. The 3 people on board apparently could not lower the anchor and all attention was there.
My son went forward and picked up a boat hook to fender them off with, just in case. The boat got closer and my son called out to them to let them know. The mouthful of abuse that came back was unbelievable, even to my innocent ears!
He asked, I thought quite nicely, if there was a competent person on board, he could speak to!
At the last minute they gave up and started the engine and went.
On another occasion we were anchored there with no other boats around. After an hour or so a motor boat appeared and circled us, I suspect he thought this was his spot!
We did not move but waved a greeting which was ignored and a few minutes later he decided to go round and round our yacht continuously until the rocking motion of our yacht was too difficult to accept.
We were forced to up anchor and move. There are some pig boaters over there!
So one case of rage and another of intentional harm.
I have seen occasions like this but 30 years ago now when we used to hire canal boats especially in the midlands! Only 1% but they stick out from the general friendliness seen elseware.
But the legal terms used according to Aberaeron harbour master ,
Reckless endangerment,
Dangerous use of watercraft likely to cause injury or death.
Plus a lot of minor offences such as causing a nuisance by inconsiderate use, failing to abide to local rules regarding protected areas.
And many more.
Rick
If you get this wrong today you need to up your tablets 😂😂😂😂😂😂
Bill 👍
Liked by
Loading…
